Announcements
Joinng 2 bodies together using boundary fill
jay.family22matt
jay.family22matt
Hey
I am trying to combine 2 different bodies with one of the bodies created from the boundary fill of the other. However, when I come to combine the 2 together, it errors and says it cant combine. Does anyone know why this happens.
Below is a screencast and some images showing my problem.
BoundryFill1.pngBoundryFill2.pngBoundryFill3.pngBoundryFill4.pngBoundryFill5.pngBoundryFill6.png
jay.family22matt
jhackney1972
Please attach your model so the Forum users can use it instead of having to recreate something similar.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
jeff_strater
You don't need a separate Combine here - Boundary Fill can do it all in one step, if you select both cells, New Body, and Remove Tools.  Screencast coming shortly (seems to be taking a long time to process)
Jeff Strater
Engineering Director
jeff_strater
Here is the screencast.  Without your design, I had to create a simpler version, but the principle should be the same:
Jeff Strater
jay.family22matt
Thanks. This was exactly what I was looking for
