Joining an Assembly to a component
harrydawson500
Message 1 of 8
harrydawson500
Whats the correct way to Join an entire assembly to another component?
When I try joining an imported assembly to my current design component just one little piece of that assembly actually completes the join function leaving the rest of the part behind. Ive tried creating a rigid group before importing the file but basically not sure what I should be doing here and tried what I think are the obvious things. Hoping someone can put me right. Cheers
Replies (7)
Message 2 of 8
g-andresen
1. show the behaviour in a screencast and share the design
2. a rigid group is not necessary before.
3. normally the other elements follow after confirming the process with ok
günther
Message 3 of 8
TrippyLighting
Indeed, in freshly imported static assemblies a rigid group including to top level origin is almost always a good idea.
Message 4 of 8
harrydawson500
Forgive my poor first shot at a screencast. Im sure It will be a stupid mistake so please let me know what Im doing wrong!
https://knowledge.autodesk.com/community/screencast/56730a0d-0346-435f-9908-a32879a21896
Message 5 of 8
g-andresen
what advantage does it bring me?
Günther
günther
Message 6 of 8
TrippyLighting
No worries. It worked 😉
Imported assemblies such as the potentiometer are design files without a design history or timeline. That is intentional as this allows "things" to be fixed without cluttering the timeline with unnecessary features.
If the imported part is only comprised of bodies all located in the top bodies folder, then you can go ahead, save the design as is, and use/insert it in other designs.
If that assembly consists of components, some work needs to be done. By default, all components in a Fusion 360 design are floating. In a DM design (Direct Modeling, so no timeline) by default components cannot be dragged around in the viewport (but there's an option to enable that) so it appears they are all assembled (not floating), but that isn't the case. If you insert such a design into another design that does have a timeline (new designs by default do have a timeline) then there you can drag all these components around, or you create an assembly joint and only that particular component is joined, but not the rest of the imported assembly.
If the imported assembly is a static assembly, so no moving parts (that would apply, for example to the potentiometer) in that assembly I would create a rigid group joint at the top level (the root of the browser) including all component origins including the top-level origin to lock them onto place.
Then when you use an assembly joint the entire imported assembly will be joined as expected.
@g-andresen the above should answer your question as well I believe.
Message 7 of 8
g-andresen
thanks
günther
Message 8 of 8
harrydawson500
Thanks! Rigid group joint as you mentioned did the trick. Cheers!
