I am trying to join a square pipe between two perpendicular square pipes at an angle (ideally the software will know the angle instead of manually calculating what the angle should be). I am unable to join the components unless I predefine an angle of the square pipe and its length, but then if there is a change, I need to recalculate the angle, rotate the component, adjust the length, rejoin the part, and then split the body and remove the excess to join the components together - seems like there is definitely a better way. I also remember reading that only 1 joint should be defined per component so how would you accomplish this with one joint so it will auto change the angle of the component and join with the other two components?
I have attached a screenshot that shows in circled red the part that needs to be connected to the other two components, and the green lines indicate the location of where it is to be connected.
Many thanks!
