Jagged lines on drawings
Why are the lines so jagged in my drawings. I'm on macOS 12, Fusion 360 2.0. Thanks Screen Shot 2021-11-17 at 10.02.13 AM.png
TrippyLighting
Those aren't lines, they are edges. "They" aren't drawings either, but 3D models or models for short.
The "jagged" lines aren't jagged, they are just not ( or not fully) anti aliased.
If you select the screen settings in the small menu bar on the bottom-center of the Fusion 360 viewport, select "Effects", you can enable "Antialiasing". If it is enabled, we'll have to look into this further.
Antialiasing is enabled.
TrippyLighting
In that case you might just have to live with it šŸ˜‰
Just to be clear, there's nothing wrong with your model or your computer!
Antialiasing is simply a visual effect that sometimes works better than others. You will see a lot less of that if you choose the "Grey room" environment, for example.
That a bummer. I wonder why my Mac does it? I was watching tutorials and the was using a Mac that didnā€™t do it.
jmanu217
Observer
Observer
just posting this in case anyone needs it.  on top right you can find this
uncheck the "Limit effects to optimize performance" box and you'll get the better display.
then you can select anti aliasing at the bottom middle of the screen.
Hope it helps!
