ITAR workaround?
gmdimarzio88
Message 1 of 8
ITAR workaround?
gmdimarzio88
Correct me if I'm wrong. If I opened a local while in offline mode, did my CAM and exported that F3D back to my local drive without going online, and Deleted the file from my Fusion project, that file should never be backed up to the cloud. Thus being ITAR compliant. Thanks
Replies (7)
Message 2 of 8
seth.madore
You really don't even need to be offline for that, you can just open a local .f3d, do your work, Export it out and it does not remain in the Cloud or your Data Panel
Seth Madore
Message 3 of 8
gmdimarzio88
Good point. If I'm in online mode I just cant save progress like I normally would. I just save locally and overwrite the local file with any updates to the file. Thanks Seth
Message 4 of 8
ajcastroQBXKG
Community Visitor
Community Visitor
Did you mean to state that  "I export locally and overwrite the local file with any updates to the file"?  I am asking because it seems that save is for the cloud.  I may have ITAR projects in Fusion 360, so I want to understand this control.  Thank you.
Message 5 of 8
engineering
BUT, can you turn OFF auto-save??
Message 6 of 8
TheCADWhisperer
You don’t have to save to the cloud.
If not Saved, then no Auto-save.
Nearly all of my files are exported locally and very rarely do I Save to the cloud.
Message 7 of 8
scott3CMTJ
Community Visitor
Community Visitor
Not sure I'm following here.  Is there a way to use Fusion, as in check a box in the admin settings to configure it so that it NEVER saves to the cloud?   It can't be where you have to go through several arcane steps to have it not save--and then one misstep is a criminal act.    Is there a cloud tokenization solution for F360 since DDTC updated its guidelines that tokenized cloud data is not an export?  https://www.govinfo.gov/content/pkg/FR-2019-12-26/pdf/2019-27438.pdf
or certain standards for security: https://www.internationaltradecomplianceupdate.com/2020/01/31/us-ddtc-issues-itar-rule-affecting-tec...
Message 8 of 8
seth.madore
No, the only button you have is the "work offline".
Seth Madore
