Issues with running a threading operation on a Haas st10Y
KrakenBuilt
KrakenBuilt
Hey there,
So my issue is when I run this threading operation when it gets to the end this is generated.
(Rewind of C-axis, make sure retracting is possible.)
M0
Z0.6 F0.8
M155
M154
G97
P2000 M133
G1 X0.0561 F470.
G0 C0.
G1 Z-0.2145 F0.8
M8
(End of rewind)
It stops everything and the door to the lathe opens. Sorry if this is an obvious thing. I'm still getting a little use to running the Haas ST10.
The threading operation is using live tooling and a rotating thread mill. There is a C-axis rotation on the chuck. I am doing two passes to get the the correct thread depth. Is there a way to generate the script without the code listed above? When it stops the endmill is still about halfway inside the whole.
What is the (Rewind of C-axis, make sure retracting is possible.) All about? I've never seen this before. I've included the full gcode here.
Thanks!
KrakenBuilt
Oh and for the post processor I'm using the latest one for the Haas ST-20Y. because I can't seem to find one that's specifically for the ST-10Y. But I kind of assume that should be okay?
Thanks!
