Issues using drawing title blocks.
Hi all,
hope you are all well.
I’ve come across an issue when attempting to use title blocks - the issue is as follows:
I create a new drawing for my part, then delete the default block. I then create a new block from scratch changing a few of the headings and adding a few new boxes, as well as putting an image in (logo). At the end of the process I exported this block as a DWG file.
However, if I was to create a new drawing for a separate component, and then try to use the drawing block by loading the DWG I have just created, I am met with a ‘Title block insert failed’ message. Upon clicking the ‘more information’ this takes me to a web page that doesn’t exist.
kind regards and thanks in advance.
