Issues combining two bodies.
sales3MPAD
Message 1 of 21
sales3MPAD
I have tried to combine two bodies unsuccessfully.  Take a hollow Box, and insert a tube into it.  I want to combine the two into a single part.  However each option under combine doesn't give me what I seek.  I am looking for them to merge, and for the tube stub inside the box to be removed and the box to have a hole into it with the tube such that looking down the tube you can see in side the box.  So far nothing works.  How do I do this?
Replies (20)
Message 2 of 21
TheCADWhisperer
Message 3 of 21
jean.flower
Hi @sales3MPAD
I wonder whether the boundary fill command might help?  It's a way of doing combine operations where you can select the part(s) you want to appear in the result.
Images show two bodies I made which I want to combine without the part of the tube inside the box.
The boundary fill dialog - selecting the green "cells" can be fiddly - as well as using the checkboxes, I hovered the mouse over different parts of the image and you can see different cells highlight
the boundary fill dialogthe boundary fill dialog
After the boundary fill completes, you have a new body
Is this the kind of result you were seeking?
Jean
Jean Flower
Product Manager
Autodesk, Inc.
Message 4 of 21
sales3MPAD
yes that is what I was seeking to do.  Never used the boundary command, not even sure where it's located to be honest.
Message 5 of 21
sales3MPAD
YES Jean that is exactly what I am seeking to do.  Tried three times no luck, def a dodgy process.  did the learn more only to find it tell me coming soon.....
Message 6 of 21
sales3MPAD
Thanks Cadwhisperer, but I can't have the part on a public forum.  The boundary fill seems like the right process, I just can't seem to get it to work regardless the cell selections made.
Message 7 of 21
sales3MPAD
Would it make any difference if the tube is coming in at 45 deg and was coming in from a corner so it's coming through two faces of the box body?  I would assume not but I am not sure what else to try.
Message 8 of 21
jean.flower
Hi @sales3MPAD glad this seems to be going in a helpful direction!
Boundary fill works for a tube coming it at 45 degrees and it also works if the tube meets multiple box faces too.
The most tricky part was selecting the correct cells.  It took a few goes to get that right when I created the images above.
Jean Flower
Product Manager
Autodesk, Inc.
Message 9 of 21
sales3MPAD
Well then I have epically failed as I have tried just selecting one cell just to see it do anything.  It remains the same afterward as it does before.
Message 10 of 21
sales3MPAD
I just thought of something.  Would it be an issue if the tubing was created from a cylinder with a hole drilled in it?  I wouldn't think so but it's the only thing I can come up with as the boundary fill is simply not working.
Message 11 of 21
TheCADWhisperer
Step 1. Create a dummy file similar to what @jean.flower that exhibits the same issues as your proprietary data.
Step 2. Attach the dummy file here.
Message 12 of 21
jean.flower
Yes, it'd be useful to get hold of a design file that's not working for you. In case it helps. I recorded a short video.  https://autode.sk/2Q024fB
Jean Flower
Product Manager
Autodesk, Inc.
Message 13 of 21
sales3MPAD
Here is the file.  I have tried clicking on every possible combination of cells, nothing produces anything changed.
thanks for the vid, it confirmed I was following the steps correctly.
Message 14 of 21
davebYYPCU
I could not select the correct cells either,
I would not model this the way you did. (4 extrudes for me)
Following your lead, used split body, combine and remove to get there.
Might help....
Message 15 of 21
sales3MPAD
Interesting approach.  So you needed to split the tube body, then you needed to split the box body then you needed to combine them, then you needed to delete the split pieces?  I tried it but likely did it wrong as I didn't get the right result.
Hopefully Jean will answer with so idea as to why the boundary fill didn't work for either of us.
Message 16 of 21
sales3MPAD
Well I managed to get the split body to work, but after moving the split part of the tube away and moving the split part of the box away, it won't allow me to delete them saying this feature is referenced by other features in the timeline do you want to delete?  Doing so blows apart the design into pieces that would require putting them back together vs the removed pieces just being deleted.  How can I delete them that doesn't require me to rebuild the part?
Message 17 of 21
davebYYPCU
Not Delete - REMOVE.
You would have none of this drama,
if you build the box, then the rod,
extrude cut the box will cut the tube as well, then extrude cut the tube.
Might help....
Message 18 of 21
sales3MPAD
Wow.  I couldn't find REMOVE.  But hey tell you what.  Don't respond to my thread further, or any of them ever.  I don't do this for a living, I am trying to learn something unfamiliar..  Go be and Ass on somebody else's time.
Message 19 of 21
davebYYPCU
So your not learning from my input - fine.
Message 20 of 21
sales3MPAD
I am interested nt help, like Jean provided.  I wasn't berated or told I have drama....  Simply shown what they did.  I hope to hear more from Jean.  How I built the parts shouldn't matter as long as they are allowed by Fusion.  Everyone has their own workflow approach.  I have looked at every dropdown, create, modify etc and no remove command shows on my version of Fusion.
