Announcements
Issue With Rolling Back / Suppressing Split Body Command
LaleveeJT
LaleveeJT
I am experiencing an issue where rolling the history back past a split body command gets rid of the bodies split. First image is the model with the body split, second image is with the history moved back past the split and the bodies all missing from the design tree. The same behavior happens when I suppress the Split Body command.
I remember in the past Fusion did not behave this way, I often will split my bodies up for rendering the wood grain more accurately and then reverse the split for drawing. This time I was able to just recombine the bodies for drawing export, but reversing / suppressing the split is way easier to do when it works.
Mac OS 13.3.1 , Fusion 2.0.16009
Screenshot 2023-05-03 at 9.31.22 AM.pngScreenshot 2023-05-03 at 9.31.36 AM.png
LaleveeJT
Anyone?
LaleveeJT
This issue continues to happen in my everyday work flow.
LaleveeJT
Still running into this issue and it's very annoying. Fusion didn't used to behave like this.
HughesTooling
Running a Compute All brings the bodies back. Might be something for support to look at. @jeff_strater What do you think?
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
