Announcements
Issue with Pipe form command
Francisco_García
Mentor Mentor
Francisco_García
Hi there.
I have detected a small problem that affects the Pipe command in the Forms environment.
It is slight but I think it should be fixed. It consists in that it is not possible to modify the ends of the form individually with the contextual menus because they do not show the 3 options. This forces me to have to do it from the properties panel of the order.
Attached is an animation of the issue.
Regards.
Fco. García Bayarri
Delineante industrial | Formador técnico
LinkedIn | YouTube | Twitter | Telegram
Por favor dame Kudos y marca esta respuesta como Solución Aceptada si responde a tu pregunta.
Please give me Kudos and mark this answer as Accept as Solution if it answers your question.
TrippyLighting
Why would that be a problem ?
The object isn't parametric and the end types available in the meu are easy enough to create manually.
Also, the sculpt pipe tool can create a pipe like the one below. How would you want to  drive the end type from a menu when the number of ends is variable?
Francisco_García
Sorry. Maybe I didn't explain myself correctly.
The bug is that the context menu has stopped working as it did in previous versions. Check this out and try to replicate it for yourself:
Fco. García Bayarri
TrippyLighting
Aha, you are right, that does not work reliably. @jeff_strater bug alarm.
Francisco_García
The issue already was fixed.
Thanks.
Fco. García Bayarri
