Issue with McMaster Carr Insert Component - All Components are incorrect
jeffdbeats
Message 1 of 10
jeffdbeats
I use Insert McMaster Carr Insert component all the time, It is amazing... but since today, every single component I have tried to is incorrect, I try to insert a timing belt, it gives me a threaded valve, I try to insert a hand crank, it inserts a tap thread... lol I think the database may have been shifted / something is messed up... it is picking the wrong components when I do - Insert .step... I don't know if this is an API error with McMaster or something on Fusion360 end, but hopefully it is fixed soon, this feature is wicked useful / I have never had issues with it in the past.
Replies (9)
Message 2 of 10
wmhazzard
Everything works fine for me. Did you restart Fusion?
Message 3 of 10
Geoff5NWER
Community Visitor
Community Visitor
I'm experiencing the same issue, even after restarting Fusion.
Message 4 of 10
mdeasla
I'm experiencing the same issue and I've updated/restarted Fusion several times.
Message 5 of 10
schack.lindemann
Same issue here. All McMaster Carr Inserts are completely random. An M12 lifting bolt ended up a Electrical-Insulating Nylon 6 6 Sleeve Washer. I've started and restarted Fusion several times since last update and results are the same. McMaster Carr Inserts are unusable at the moment.
On that note, I also have issues with the browser disappearing all the time. I've posted about that elsewhere and it seems to be a macOS only problem.
Message 6 of 10
zthee
Same issue here. Importing a bolt, getting a pump. Tried to update and restart, does nothing. Also on macOS.
Message 7 of 10
Phil.E
Confirming: Is everyone on macOS? Anyone with windows seeing the issue?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 10
jeffdbeats
Windows here, I reached out to McMaster Carr and they said they fixed problem, I can confirm it is working now.
"Hi Jeffrey,
I'm sorry our website was not downloading the correct McMaster-Carr CAD files. We resolved the issue, and you should now be able to download our files properly."
Message 9 of 10
jeffdbeats
"Hi Jeffrey,
files properly."
Message 10 of 10
Phil.E
Thanks for the update!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
