Issue with axis using revolve
Message 1 of 9
Hi everybody,
I have another one for you:
Using revolve if I select an axis that's not on the same plane as the selected profile then the profile is spun around one of its edges instead of the selected axis. BUT if I set the angle back to zero and rotate the view a bit it magically starts working correctly. Sometimes the angle is reversed though.
See attached srceencast!
Thanks in advance!
Replies (8)
Message 2 of 9
Well, this page didn't like it's own URL to the screencast and it removed it....
So here it is again!
Edit: After posting this the screencast showed up on my first post..... It is a weird day today.....
Message 3 of 9
MoshiurRashid
Hello @Anonymous
I've tried the same way several times but couldn't find any issue from my end. May be it is something from specifically your software. Would you please try extrude a rectangle this time and revolve it again?
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 4 of 9
Hi!
Thanks for getting back to me!
I've tried to extrude a rectangle from a sketch and then revolve a face but got the same result. I can record a screeencast if it helps but it will look the same.
Message 5 of 9
MoshiurRashid
Is the revolve axis is moving from there or it is still there and you are getting the weird result?
Moshiur Rashid
ACP | CSWE
LINKEDIN | FACEBOOK
Message 6 of 9
You mean the selection? No. It never moves. The same line stays selected that I select in the beginning and that line doesn't move either if that's what you meant.
Message 7 of 9
I was just playing around with a box and noticed that I don't need to change the view in order for the axis to be correct. If I set the angle back to 0 and move the mouse a bit so the angle slider (I don't know the correct term) goes unselected and then try to spin the object then it starts to work right. I record a screencast to make it more clear.
Edit: Well, it seems like it doesn't fix itself after all... If I click OK it jumps back to the wrong axis. See screencast!
Message 8 of 9
@MoshiurRashid, you mentioned that you could not recreate the problem on your computer. I went home and tried it on my other machine and the issue exists there as well.
For reference:
Machine #1: Intel i7 with Nvidia Quadro
Machine #2: AMD Ryzen with AMD Radeon
Both machines run up-to-date Windows 10 PRO 64-bit
Message 9 of 9
I just tried the same on a coworker's machine with his account and same issue exist there as well.
If I revolve a face of an object or a sketch around an axis that's not in the same plane as the face then it revolves around a different axis instead of the one I selected.
