Announcements
Issue with Autodesk connect
Recently the desktop connect will not  load due to  the attached error any ideas, my network is fine and nothing has changed
dsouzasujay
Hi @Anonymous ,
Is this the first time you have installed desktop connector? What is the current desktop connector you have?
Did you try uninstalling and installing latest desktop connector?
If it still didn't fix, pease follow THIS link.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Hi It has been working fine uptill about a week ago I presume its the app called DesktopConnector.Applications.Tray.exe if so  its V14.6.0.1242
I will try an uninstall and reinstall to see what happens
Hi So reinstalled with the latest version and getting the same issues Version is 14.8.0.1381
dsouzasujay
@Anonymous ,
Please follow THIS link.
I can see a possible solution listed.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
SO disabled yper v then tryied the next step and get
but autodesk connector  started after disabling hyper V, But i need hyper v as i need this for my work to run Docker containers in windows
