Fusion Support
isac controler
5 REPLIES 5
gringo.rest
324 Views, 5 Replies
isac controler
hay all just bought a new cnc machine that has a isac controller i an using fusion 360 to post process and i am looking for a post process for an isac if any one can help i will appreciate that or direct me to a professional that can help me create a custom processor for the machine i have a flexa pro from aes
thank you in advance
Ore
5 REPLIES 5
will_1
in reply to: gringo.rest
Hi @gringo.rest ,
It is hard to say without seeing the actual code, but the rs274 post processor might work fine for you.  Send some sample code and I can give you a better idea, or try it out yourself.
https://cam.autodesk.com/hsmposts?p=rs274
If you do need a new post processor made you will find the link below useful.
https://forums.autodesk.com/t5/hsm-post-processor-forum/hsm-post-adjustments-needed-find-your-right-...
Let me know if that helps at all.
Will
gringo.rest
in reply to: will_1
thank you for the replay i add a post for the isac controller
gringo.rest
hay i just got my new cnc machine and the machine works with an isac controller. the current list of fusion 360 is lacking the isac post processor if there is any one that can help me with that issue i will greatly appreciate that
i am uploading a post that i got from alphacam that came with the machine
will_1
Hi @gringo.rest ,
You can request the post processor on our post ideas site for people to vote on.
https://forums.autodesk.com/t5/hsm-post-processor-ideas/idb-p/985/tab/most-recent
Will
Did you ever resolve this issue ?  I have the same problem
