Message 1 of 17
08:41 AM
I made a design in Fusion and exported an STL of it. It "sliced" without a complaint for my 3D printer but with its taking six days {!}to print I thought I'd check shapeways. Shapeways kept telling me there was an error in the STL file!! I contacted customer support at Shapeways and this is what they told me:
It was a loose shell issue. So it contained about 5000+ shells. Loose shells can be any number of different issues- flipped triangles, bad mesh, etc. So it's not a bug issue but more that the files need to be checked after exporting. Sort of like when you touch up a photo in photoshop, you would need to preview it as it doesn't always look the same from the source. Meshmixer is a free tool you could use. So after you export a model from Fusion, you open it in meshmixer and make it a "solid Part".
I know nothing about shells and flipped triangles and such. Is this an actual bug in Fusion's STL generating machinery? Since I have no way to "check" the STL, should I just start always running meshmixer as a matter of course after I export an STL?
