Announcements
Is there a way to easily see/break all sketch links to projected geometry?
pkmiotczyk
pkmiotczyk
Hi!
I would like to move a sketch in timeline in such a way which violates current projection links.
How can I open the sketch and break all projection links without having to go point-by-point, and line-by-line, hovering and then deleting?
I know for a fact that missing projection sources enable you to click the exlamation mark and open a dialog which lists all sketch links and allows you to address them. I would like e.g. to open exactly a dialog like this to proactively break all the links. Failing that is there any other efficient way?
Thanks!
wmhazzard
You can window select the projected geometry, right click and select break link.
pkmiotczyk
OK, that answers the question. Thank you.
Is this the only way or is there some other option, preferably including
showing an outline of all links?
wmhazzard
I believe that is the only way. You can however, deselect projection link in the Project dialog box so there is no link from the beginning.
pkmiotczyk
Thanks!
you can select the projected drawing , copy the drawing then paste the drawing after moving it to one side .
all projected links will be deleted.
i think this is what u are asking.
so select drawing right click on screen to get copy command, copy then paste
hope this helps u
