Fusion Support
Is there a way to deselect edges from a face selection in chamfer/fillet?
2 REPLIES 2
CL9YAJC
143 Views, 2 Replies
I'm wanting to face select both sides of this part to chamfer everything inside it, and deselect all the countersunk holes so it doesn't try to chamfer them again. Is there a way to do this or do I have to select each individual edge...Screenshot 2023-08-08 104047.png
2 REPLIES 2
jhackney1972
in reply to: CL9YAJC
If you countersink holes are placed last, in your timeline, you can simply move the timeline marker before the holes, do the chamfer using faces, then drag the timeline back to the end of the timeline to return the holes.  If you holes are not at the end of the timeline, you may be able to move them there first.
If this is not feasible, you are probably destine to do it using the long method.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
jeff_strater
If you select a face, that is defined to select ALL edges of that face.  You can, however, window-select edges (set your filter to just edges), then de-select the edges you don't want by holding down CTRL (CMD) on Mac.
Jeff Strater
Engineering Director
