Is Sketching Still Broke?
Why can I Extrude Sketch3 as a solid, but not as a surface body?
(Actually, I wanted to do the Trim as on operation, but you get the idea...)
I had originally create the four corners as 3Point Rectangles and changed one line of each rectangle to Construction.
When I couldn't select loop (in one selection), I deleted the construction lines. Still no go...
No Loop in One Pick
Edit: A bit more experimentation I can select in multiple selections, but why not one loop selection?
Also, the surface to trim selection did not always turn red, but did work?
