Is "fillet" broken, too weak, or am I missing some command options?
When filleting a simple solid that was generated by extruding 2 ellipses with connecting lines, I can't get Fusion to fillet the edges beyond a very small radius (not nearly enough, I need 10mm). See the pictures attached for the profile.
To double-check that I was not drawing the profile with errors, I imported the same geometry as STEP into Fusion, SW, and Plasticity. Fillet works in the other 2 CAD software but not Fusion. Is "fillet" broken in Fusion, or is the math engine behind it not strong enough?
Or, am I missing some options / selections within the fillet command that could help? I've looked and looked, but maybe missed something. Your help would be much appreciated. This is a basic and annoying road block.
