Is it possible to hollow a coil or draw a "coil shape" path for a pipe extrusion to follow?
Have you tried Shell? Select both end faces then enter an offset. Note if you need to add faces to a selection after entering an offset you need to hold the Ctrl key down to suppress the offset.
Mark
Mark Hughes
Owner, Hughes Tooling
