Fusion Support
Is it possible to extrude only the lines, without making it solid?
4 REPLIES 4
mick_danger09
105 Views, 4 Replies
Trying to make something similar to pic 1 but cant figure out how to extrude it.
4 REPLIES 4
Have you tried thin wall extrude? You can select profiles or individual curves, uncheck chaining for individual curves.
Mark Hughes
Owner, Hughes Tooling
g-andresen
in reply to: mick_danger09
1. What should be the end result?
2. Is the size as expected?
günther
@mick_danger09
Examine the Attached...
mick_danger09
in reply to: g-andresen
Thanks man, I'm really new to modelling so I didnt understand how to do this.
