Fusion Support
Is it possible to dimension from a midpoint when in Drawing mode?
3 REPLIES 3
martin
429 Views, 3 Replies
3 REPLIES 3
eellenburg
in reply to: martin
Yes.  Activate the dimension command then right click and select midpoint.
martin
in reply to: eellenburg
The message does not contain any threats
AVG for MS Exchange Server (2012.0.2265 - 4365/15297)
AshleyJ45Q6
There is no mid point function in with dimensions in drawing view
need mid point of one hole line to other when holes are offset very common why to measure to make the part
This works when creating the model to offset the lines
