Is it possible to control output options for IGES files?
- Mute
- Permalink
- Report
We operate a laser cutting shop and have a tubing laser. We need to generate files to run on the machine, which only uses IGES files. Specifically, files that are saved as surfaces, trimmed, using NURBS. We thought we may be able to use Fusion, but they are not the correct type of file apparently. There is data, but the machine software will not open it. We are using CypTube control software and so far the only files we have been able to use have come from Inventor LT and Solidworks.
I can design a project in Fusion, export it as an IGES and bring it into Inventor LT, then save it out again with the proper settings. That works fine, but I would prefer to get back to the Fusion environment if possible. We also have a CNC router and the CAM in Fusion is great for that. It would be nice to have one platform to service both machines instead of jumping around.
