I have come across this issue several times, and the annoyance of it is finally getting to me.
Several times I seem to get a random profile, that is not really being generated by anything. You can select it but it does not highlight it like a normal profile. Hold Clicking you can see both profiles where there should only be one. In some cases you can see the overlap colors of the profile areas. When using these sketches for features, you have to Hold click select all of the profiles you want to use, because it quickly flashes between the one you want and the Fake one.
I do know about the profiles generated when you create a sketch off of an object, but those you can easily remove by setting the invisible profile lines to construction.
The below sketch was drawn on the XY plane. You can sort of see that there seems to be a ghost profile of all the lines. You can see around the circles that there seems to be a ghost circle offset from it, but none of it can be interacted with.
