I am trying to select the proper tool for a job and anytime I select a round nose tool from the library I get the above error. The tool I am using is a core box bit from Lee Valley. (D:.3/4", cutting length: 1.25", R:3/8"). The closest thing I can find is from an imported tool from Whiteside (1406 round-nose bit). The radius and diameter are the same. Cut depth and shaft size don't matter for what I'm doing here.
The tool path is a 3D scallop. Basically a 15 degree ramp to clean up a band sawn scarf joint.
I would like to create a proper tool in my library for this bit. Vcarve has the ability to create tool entries by drawing a half profile of the bit. Is there a way to do that in Fusion?
So I guess I have two questions here. Why am I getting this error when I try to use the Whiteside 1406 round nose router bit (or any of this type) to mill a scallop, and second, how can I create a proper tool in my library?
I have attached the Fusion file and screenshots of the bits.
