Announcements
Intersect command missing
erwin
erwin
Today, when designing something, I wanted to make a section cut, but when I typen "S" and then inetersect, the command did not show up. Restarted Fusion, made a clean new model nothing worked. The intersect command is gone....... Any ideas what is causing this?? I am also missing things like project, that would normally appear when I search for it when using S
g-andresen
Project / Intersect is part of the sketching tools and only appears in active sketching mode.
günther
erwin
Hi Günther,
thanks for that, in the previous versions, I could select intersect, then pcik a plane, and the it woud switch to sketching automatcally..... Did not occur to me I have to now select the sketch, before going to intersect, it works fine, many thanks, was going crazy.....
Erwin
g-andresen
I think we are talking about different things here.
Project/Intersect has always been a sketching tool.
Split Body, on the other hand, takes place in the area of solids and uses layers or sketch elements as editing tools.
günther
