Announcements
Internal CAM Kernal Error
lukeQVK6E
Observer
lukeQVK6E
Observer
Observer
I have been using Fusion to machine mostly simple 2d contours for the past year. Just starting today every time I setup/generate a new toolpath I will get the "Error: Internal CAM kernel error. Please report through your support channel." Message.
I have gone back to many old projects and toolpaths (that I know work) and re-generated the toolpaths for them and am getting the same error on those as well. I have tried running many other toolpaths (adaptive clearing, pocket, etc...) and am getting this error. I have changed just about everything for the contour cut but am still getting this error. I have changed everything in my setup and the error still shows up.
Attached is a simple 2d contour cut file with the error. Any help is greatly appreciated! Thanks
Replies (11)
seth.madore
Yep, known bug. Remove any special (non-ascii) characters from the tool name.
Seth Madore
TraderRick
I too can not re-generate any tool paths from projects that were just in use even yesterday unless i open them on a pc that hasn't installed the update.....they re-generate fine if the update is not installed.....what you mentioned of re-naming the tool seems to work on the computer that has the update installed.....please roll back the update or fix this issue asap...i'm sure many of us are busy and need to be able to generate toolpaths today without re-naming hundreds of tools
eduardo_sanchez2
Hi Seth,
can you please give an example of what a non-ascii character is?
Having the same problem right now.
Thanks a lot,
Ed
eduardo_sanchez2
Hi Traderick,
cannot be more on the same page as you are....
Do you know how to contact the support people directly?
Seth has been very kind and helpful as always.
Thanks a lot,
Ed
seth.madore
ê,õ, diameter symbol, degree symbol, other non-english characters for our friends around the world
Seth Madore
seth.madore
And for those of you that have Commercial accounts, you can click on this:
Seth Madore
TraderRick
Just to follow up......I have gotten the few parts re-programmed that i need today by editing the tool in each toolpath and setting it to 1 letter....that has gotten the toolpaths to generate for now, but that won't work for the future for me.......most of my tool descriptions come from the HELICAL tool library and they don't work.....hopefully they are working out this problem and will have a fix soon.....I haven't talked to anybody directly as I've been re-naming tools all day to get my work done....lol
seth.madore
We hope to have a fix for this out in the next hotfix. Terribly sorry for this inconvenience!
You should be able to proceed with anything in the English alphabet, so: ".250 ENDMILL_1.0 LOC" should work (minus the "")
Seth Madore
lukeQVK6E
Observer
Observer
That fixed the error. Thanks!
eduardo_sanchez2
Hi Seth/Everybody,
Thanks a lot for your help! running again!
Eduardo
TraderRick
This appears to have been fixed with an update this morning........Thank You for the quick action!!
