Internal CAM error
chaikenm04L65CL
Observer
Observer
Internal CAM error
chaikenm04L65CL
Observer
Observer
I just updated Fusion 360 today  and now I have been getting this error regardless of what file or shape I am trying to generate 2D contour tool paths.  Has anyone run into this error?
Enabled feature flags: online-system-library setup-sheet-configurations setup-sheet-viewer tool-library-v4-release
Invalidated: Generation failed
Error: Internal CAM kernel error. Please report through your support channel.
Replies (7)
mredmatters
Community Visitor
Community Visitor
I too am having the same problem
can't make any Toolpaths without getting this error:
Enabled feature flags: online-system-library setup-sheet-viewer tool-library-v4-release
bmcihk
Im having the same issue after software update, did anybody find a solution on how to get back to business?
seth.madore
Yep, known bug. Remove any special (non-ascii) characters from the tool name
Seth Madore
TJS01
Same issue here.  Gotta love those updates and super helpful error messages!
seth.madore
All; Restart Fusion, grab the latest update that rolled out today to address these issues, restart, and this should be resolved.
Seth Madore
chaikenm04L65CL
Observer
Observer
I actually found a post regarding the problem. In the last update there is
an error in how the program deals with some characters in the alphabet.
They recommended making a copy of your desired tool and simplify the name
to jot contain any Cyrillic notations. I use the Amanda tools library. I
stripped the 46200 tool down to just that number and everything works fine.
They say they are working on a fix. Hope that helps.
seth.madore
All; this has been fixed in a recent update. Restart Fusion to trigger the update, restart again to consume the update.
Seth Madore
