I am a total noob to Fusion and just getting started learning it from scratch. That said I'm all for simplifying the process. Most of the parts I want to model an relatively simple compared to what Fusion can do. So thanks for the help and suggestions. Now if I can just figure out how you did what you did using the sketch and revolve tool. LOL
And just to clarify when modeling an internal thread I have to make the hole the largest major diameter of the external thread that mates with it???? I'm assuming that if you want a specific minor to override Fusion you have to use the create custom thread thing?
I think I should mention that I am not machining anything on CNC equipment. I do all my machining on a manual lathe so what might make sense for someone that does use CNC doesn't translate totally to me. I can't just tell the machine to make a 13/16 20 TPI thread.
Another thing that came up while looking at the file you made... Whenever I machine a thread I create a lead in chamfer. I've gone in and edited the project you posted by adding chamfers at the start of the threads. Is it better to add the chamfer to the shoulder of where the thread will start before modeling the thread or after? Maybe you draw the chamfers when making the 2D sketch before revolving??? Here's my issue if the program expects the bore dimension to be that of the major of the mating external thread how does one specify where the lead in chamfer is? IOW on that specific part, on the 13/16 20 thread I want the lead in chamfer, which also is the ID for an O-ring, to stop .085" from the edge of the part.
I'm sure all this is very basic stuff to those that are familiar with the program so I apologize for all the questions. I guess I think in terms of how I'm going to actually machine the part. For instance to machine the 13/16 thread end of the part I would drill to rough diameter, cut lead in chamfer and O-ring ID with a 45 degree internal chamfer tool, bore ID to minor thread diameter, then machine the threads.
