Announcements
installation problems
bonsignoreal
Observer Observer
bonsignoreal
Observer
Observer
Hi, I recently formatted my PC and of course I'm reinstalling Fusion 360 but the following message appears.
I have windows 11 23H2. I also attach the log file
RajkumarIlanchelian
@bonsignoreal Can you please try the below?
1. Make sure that Fusion installer is not running in task manager
2. Go to C:\Users\user\AppData\Local\ DELETE folder Autodesk\
3. Do not use the same Fusion installer. Can you please download the installer again? (make sure that 360 is not found in the installer name)
4. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
bonsignoreal
Observer
Observer
I did everything you said but I didn't solve it
RajkumarIlanchelian
@bonsignoreal On your desktop do you see a Fusion shortcut? If so can you delete that as well and install again please?
Autodesk Fusion
Join Fusion Insider
