Fusion Support
Insert fastener not "loading"
4 REPLIES 4
eladm
161 Views, 4 Replies
Hello All
When I tried to use the command Insert fastener
the command not "start" I change the Wifi , and also check the URL connectivity (network diagnostic tool) that check OK
Is someone have this issue ? how can I solve it ?
best regards
4 REPLIES 4
Warmingup1953
in reply to: eladm
What license do you utilise?
eladm
in reply to: Warmingup1953
My fusion is not for hobbyist or education
Roman_Vesely
in reply to: eladm
Hi Eladm,
 we are very sorry for issue with using Insert Fastener command. It seems to be working well on our side, so it could be some temporary outage of our service(s) which should be resolved now.
Could you try to restart the Fusion and start Insert Fastener command again, please ?
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
eladm
in reply to: Roman_Vesely
Hi
restart didn't helped .I think this command "using" a web site that blocked , the network diagnostic is all OK
regards
