Fusion Support
insert fastener icon doesn't appear in 2.0.16985 x86_64
3 REPLIES 3
gtoner2506
144 Views, 3 Replies
I don't see the insert fastener icon in the solid toolbar along with the insert fastener in the drop down menu. I'm a single user running
2.0.16985 x86_64. Any help?
3 REPLIES 3
jhackney1972
in reply to: gtoner2506
Insert Fastener command was released in version 2.0.17710.  You will need to update your Fusion 360 Version.  Another requirement to use the Insert Fastener command is you must be using a Team Hub for your file storage.  It will not function with Single User Storage.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
gtoner2506
in reply to: jhackney1972
Fusion says I have the latest update installed.
jhackney1972
As you can see by the version I posted, your version is not up to date.  You may want to use the Fusion 360 Service Utility to Repair you version.
John Hackney
Retired
