I have a target design where I insert a derive, a source design consisting of multiple components.
When I add a new component to the source design, and then update the target, the new component is included in the target design as you would expect, but it doesn't stay in the right place relative to the other components in the source design after move/copy in the target history- the older components get moved all together with move/copy operations in my target design, the new component is at a different place.
Is there a fix that doesn't involve moving the new component manually?
Can you edit the Move and add/select the new components? Also Move is usually the wrong way to position components, you should use joints.
Mark
Mark Hughes
Owner, Hughes Tooling
