Injection Molding Simulation Results Broken
lrichardWU4X6
lrichardWU4X6
Hello, for about a month or so, every time I try and open Injection molding simulation results - the program crashes. I've tried simple and complex parts and loading results that previously worked and it crashes the program every time. I also uninstalled and reinstalled Fusion to see if that would help and it did not. Still crashes every time I try and view results. Is this a known bug? If so, when will this be fixed?
Replies (22)
mcmillr
One last suggestion, I don't know your exact model number but if you check your exact machine specs and there is an AMD graphics chip also present on the machine you may be able to disable the Intel HD graphics and force the machine to use the AMD, which may solve the problem.
You can also run a check on WebGL using this link, but I am not sure if this will point out any errors or simply display a bunch of information about your hardware and software configuration.
https://webglreport.com/?v=2
Rob McMillan
Software Architect, Fusion Simulation
mcmillr
You can also visit
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/4GAYwrd9SV4MJlh68wUATv.html
and see if you can get access to Fusion online.
Rob McMillan
tommaso_rizzolo
The online version works! Thank you very much
