Announcements
Infrared Dryer Thermal Stress Simulation - For Capstone Project - Heat is not distributing inside the Dryer
2021jbvalcantara
2021jbvalcantara
Already posted a Document regarding the simulation, I cant seem to have a distribution of heat. even if I added air body or Elevate the values.
already tried to have advance properties in the IR Lamp, different thermal expansion coefficient and such.
henderh
Hi @2021jbvalcantara,
Could you attach the dataset, or a simplified one that shows the issue? I didn't spot it in another thread.
  • File > Export... > Autodesk Fusion Archive Files (*.f3d)
  Thank you,
Hugh Henderson
QA Engineer (Fusion Simulation)
2021jbvalcantara
Here, Thank you
