Incorrect Hole Size in Drawing With Nested Holes
adamautodeskP9BFL
adamautodeskP9BFL
I encounter an issue this morning when trying to draw a motor mount I designed with nested holes. The bug can reproduced with three nested holes (an 80x10, a 60x1.5, and a 16). When I go to draw this part and use the "Hole and Thread Note" it places incorrect hole sizes/depths. Please find a simple repro f3d and the resulting drawing.
-Adam
jhackney1972
You seemed to have found a problem with the Hole & Thread Note, I could verify it.  @jeff_strater, I hope you will be able to take a look at this and see if you agree.  I changed my model around a bit to make see it it helps but did not.  I attached it for your to compare to @adamautodeskP9BFL model is needed.  My drawing is shown below.  Thanks
John Hackney, Retired
sarang.rajpurohitV2DJE
Thank you for reporting this issue.
The reason for this behaviour is that two holes are sharing common edge as shown in "common_edge.png". If this edge is selected in the front view we obtain hole information from the first hole feature associated with this edge and populate the data. We can reproduce this bug and have logged a ticket.
As a workaround as shown in multipleViews.png I have created section view and projected view. In both views I selected the edges which are unique to that hole. You can see if we select unique edges we get proper hole information.
Thank you,
Sarang Rajpurohit
(Sr. Software Engineer)
