Fusion Support
Inability to install Fusion 360 on Mac M1
3 REPLIES 3
eplan
123 Views, 3 Replies
I'm getting the errno13 permission denied when attempting to install Fusion 360 on an educational license, mac m1 Sonoma 14.1.2. Ive gone through the trouble shooting steps here: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Resolving-Installa...
These are the logs:
2024-03-19 23:27:12,183 - MainProcess(1187) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: /Users/owen/Library/Logs/autodesk.webdeploy.streamer.log
2024-03-19 23:27:12,183 - MainProcess(1187) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-03-19 23:27:12,183 - MainProcess(1187) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-03-19 23:27:12,183 - MainProcess(1187) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x1040d0250> #
2024-03-19 23:27:12,183 - MainProcess(1187) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-03-19 23:27:12,183 - MainProcess(1187) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from /Volumes/Autodesk Fusion Installer/Install Autodesk Fusion.app/Contents/MacOS/resources/buildinfo.json
2024-03-19 23:27:12,183 - MainProcess(1187) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-03-19 23:27:12,183 - MainProcess(1187) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231212154431
2024-03-19 23:27:12,192 - MainProcess(1187) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2024-03-19 23:27:12,192 - MainProcess(1187) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: /Volumes/Autodesk Fusion Installer/Install Autodesk Fusion.app/Contents/MacOS/resources
2024-03-19 23:27:12,193 - MainProcess(1187) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to /Volumes/Autodesk Fusion Installer/Install Autodesk Fusion.app/Contents/MacOS/certs.pem
2024-03-19 23:27:12,193 - MainProcess(1187) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-03-19 23:27:12,194 - MainProcess(1187) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-03-19 23:27:12,194 - MainProcess(1187) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-03-19 23:27:12,194 - MainProcess(1187) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x1040b7920>, operation=<function multiple_operate at 0x103bbf7e0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-03-19 23:27:12,194 - MainProcess(1187) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-03-19 23:27:12,194 - MainProcess(1187) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-03-19 23:27:12,194 - MainProcess(1187) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-03-19 23:27:12,194 - MainProcess(1187) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-03-19 23:27:13,297 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-03-19 23:27:13,323 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-03-19 23:27:13,833 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host autodesk.com is accessible
2024-03-19 23:27:13,835 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuMjEuMTg5LjExMw==
2024-03-19 23:27:13,836 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get client ip address [Errno 8] nodename nor servname provided, or not known.
2024-03-19 23:27:13,837 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I:
2024-03-19 23:27:13,916 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOgkJMTkyLjE2OC4xLjI1NCwgQWRkcmVzczoJMTkyLjE2OC4xLjI1NCM1Mw==
2024-03-19 23:27:13,917 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-03-19 23:27:13,917 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1185, in execute
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1503, in execute_check
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 543, in _init_registry
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process_utils.py", line 117, in newregistry
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/registry_root.py", line 52, in install_registry_root
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/registry_root.py", line 41, in _new_reg_root_helper
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/registry.py", line 569, in __init__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/registry.py", line 118, in __init__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/utils.py", line 230, in __call__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/utils.py", line 433, in makedirs
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/utils.py", line 444, in makedirs
PermissionError: [Errno 13] Permission denied: '/Users/owen/Library/Application Support/Autodesk/webdeploy'
2024-03-19 23:27:15,945 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-03-19 23:27:15,946 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy [Errno 13] Permission denied: '/Users/owen/Library/Application Support/Autodesk/webdeploy'
2024-03-19 23:27:16,856 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-03-19 23:27:16,856 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-03-19 23:27:16,856 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-03-19 23:27:16,856 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x1040d0250> #
2024-03-19 23:27:16,856 - MainProcess(1187) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-03-22 10:16:47,538 - MainProcess(16472) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: /Users/owen/Library/Logs/autodesk.webdeploy.streamer.log
2024-03-22 10:16:47,540 - MainProcess(16472) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-03-22 10:16:47,540 - MainProcess(16472) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-03-22 10:16:47,540 - MainProcess(16472) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x104928410> #
2024-03-22 10:16:47,540 - MainProcess(16472) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-03-22 10:16:47,540 - MainProcess(16472) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from /Volumes/Autodesk Fusion Installer/Install Autodesk Fusion.app/Contents/MacOS/resources/buildinfo.json
2024-03-22 10:16:47,540 - MainProcess(16472) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-03-22 10:16:47,540 - MainProcess(16472) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231212154431
2024-03-22 10:16:47,548 - MainProcess(16472) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2024-03-22 10:16:47,548 - MainProcess(16472) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: /Volumes/Autodesk Fusion Installer/Install Autodesk Fusion.app/Contents/MacOS/resources
2024-03-22 10:16:47,549 - MainProcess(16472) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to /Volumes/Autodesk Fusion Installer/Install Autodesk Fusion.app/Contents/MacOS/certs.pem
2024-03-22 10:16:47,549 - MainProcess(16472) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-03-22 10:16:47,549 - MainProcess(16472) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-03-22 10:16:47,549 - MainProcess(16472) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-03-22 10:16:47,549 - MainProcess(16472) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x10490f920>, operation=<function multiple_operate at 0x103f237e0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-03-22 10:16:47,549 - MainProcess(16472) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-03-22 10:16:47,549 - MainProcess(16472) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-03-22 10:16:47,550 - MainProcess(16472) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-03-22 10:16:47,550 - MainProcess(16472) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-03-22 10:16:48,648 - MainProcess(16472) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-03-22 10:16:48,781 - MainProcess(16472) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-03-22 10:16:49,422 - MainProcess(16472) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host autodesk.com is accessible
2024-03-22 10:16:49,425 - MainProcess(16472) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: NTAuMTkuMTQ5LjQ=
2024-03-22 10:16:49,426 - MainProcess(16472) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get client ip address [Errno 8] nodename nor servname provided, or not known.
2024-03-22 10:16:49,427 - MainProcess(16472) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I:
2024-03-22 10:16:49,507 - MainProcess(16472) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOgkJMTAuMC4yMC4xMiwgQWRkcmVzczoJMTAuMC4yMC4xMiM1Mw==
2024-03-22 10:16:49,507 - MainProcess(16472) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-03-22 10:16:49,508 - MainProcess(16472) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
3 REPLIES 3
CGBenner
in reply to: eplan
@eplan
Welcome to the forum.  Thank you for sharing the log file information.  Hopefully someone here can help you solve this.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
RajkumarIlanchelian
in reply to: eplan
@eplan Taking a look at the logs you attached. Will reply back here soon.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
in reply to: eplan
@eplan Per this article - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fusion-360-Install... can you check the section "Check Permissions" and see if you have access to this location?
Autodesk Fusion
Join Fusion Insider
