Announcements
Impossible to convert in STL + wrong save
slybaoth
Community Visitor
slybaoth
Community Visitor
Community Visitor
I'm currently doing several variation of a model (badge support with my company name + the department inscription).
I've made a first version for a given departement then, for the new variation, I save as and I make the change.
It worked quite well but for the latest design, I notice that after modification, the saving is very long, then the export in STL is even longer and finish with ERROR. Then, I close Fusion. I open it again, load the model and... nothing, the model is empty, no body or can not develop the body tree... But the miniature seems ok.
Any clues ?
Thank in advance
helibum
Are you attempting to edit it as a mesh? If so, try converting it to a solid using the Convert Mesh option in the MESH>MODIFY menu and then doing regular solid operations on it. If the mesh is complex enough, conversion may not work.
TheCADWhisperer
@slybaoth
