I'm trying to import a DXF file exported from Inkscape into Fusion 360. I can import the file alright but its scaled is way off. How do I get it to import in 1:1 scale? The base unit in Inkscape is set to mm and then in F360 its in mm. I changed this to in in both but that did not work. I also tried saving it as SVG in Inkscape and then did an insert SVG (the DXF was also done using 'Insert DXF' option) but in this case nothing imports at all.
