Message 1 of 10
Hi -
I am using Altium designer for EE designs and Fusion360 for anything MCAD. I much prefer the rendering capabilities of Fusion so would like to se my Altium boards into Fusions to render and design the enclosure.
I tried three methods, none of which was very successful;
- Exporting STEP file from Altium and then import that STEP file into Fusion. It works but the result is a terrible flat object with no copper for example.
- Exporting the file via MCAD co-designer. I installed the plugin in Fusion and successfully "pulled" the file from Altium365. The result is even worse I am afraid. All copper are outlines only and the rest of the board is translucent. I have attached a screen grab.
- Lastly I exported the Altium Board file to PCAD ACSII and then import it via the ULP command import-accel.ulp. This however presents and error and does not import the board file at all.
I have read on the Altium Co-Desginer forum that some people with the small business (hobbyist) license are experiencing problems importing into Fusion as well and it is suggested that the free versions of Fusion does not support Parasolid Format which might be the problem.
Is this indeed the case? Looking forward to any suggestions 🙂
