Fusion Support
importing a stl bug
0 REPLIES 0
Message 1 of 1
wormpower32
72 Views, 0 Replies
importing a stl bug
i have been trying to import and edit a stl file.
when ever i import the stl and generate face groups. somehow the object when i export as stl loses 2 layers in the middle of the object.
the only 3 things i did were
insert Mesh
generate face groups, select accurate, tolerance 0.001 mm
export stl
opah_extruder_brace_v0.4 is the original file
Moarstrudder Brace v4 is exported stl
when you look at the latter in layer view in cura. there are 2 whole layers missing layers.
what am i doing wrong?
0 REPLIES 0
