Announcements
importing a drawing from one fusion file into a new project and more questions please
litodrums
litodrums
I've been watching how to use F360 to create an animated exploded view .  Over a long period of time I have drawn several components and saved them in different files in F360. I would like to use these files to create one animated exploded view file.  How do I move/import these files I've created in F360 into one project file, save it, then create the exploded view file? I build one of a kind snare drums and cnc custom parts which are created in F360.
www.transnaredrum.com
Thank you for your input, knowledge
Phil.E
Glad to help.
The process you are describing is called, in general terms "assembly". The process of assembling components that make up a drum kit, in your case. Much like assembly in physical reality, to get a drum kit, you must assemble it.
So, let's get this part out of the way. Here are some learning materials to help you:
Start with this page from the Help documentation for "assemblies": Link
If you wish to read more, there's plenty more there but it gets pretty deep compared to your task at hand.
Then read this about Joints. Joints are the tools that provide position and motion (or lack thereof) for your parts. Link
And finally, the workflow you'll need to get all the components into one place. The top part of this page describes the steps to bring different design files together using "insert". Link
Here is a tutorial that closely resembles the workflow you'll be using. Link
And if a webinar approach is what you like best, here's a class from Autodesk University:
Joints in Fusion 360: A Guide to Assembly Position and Motion
Exploded views are made using the Animation workspace. Link
And then calling them up in drawings. This tutorial explains it pretty well, just for information. You can try the whole drawings tutorials if you find them interesting. Link
Let me know if you have any questions,
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
litodrums
Phil thank you very much for ALL the links.  I will take the time to review what you have sent me. A lot to learn.
Thank you for your time to respond to my post. I appreciate it very much.
phil_eichmiller
(oops posting on my educational account. This is Phil.E)
Glad to help. Feel free to mark my response as a solution if you feel it will help other people with similar questions.
