Imported terminal block STEP file from Wurth Elektronik. JOIN does not seem to work with the whole component (leaving some of the bodies behind).
Tried to use JOIN to insert the terminal block into another assembly but was not able to move the whole terminal block as a component (leaving some of the bodies of the terminal block behind).
Please advise on how to use imported STEP file as a whole component.
Thank you very much!
