The inbuilt fonts in Fusion 360 are not suitable for a laser cutter. The stencil font was the closest to usable but the gaps are too small and not designed for a laser cutter. I then downloaded some fonts online from https://www.1001freefonts.com/. The files came in a .ttf file and so I then converted them into an .otf file through https://www.fontconverter.org/.
I then went to Windows -> Fonts and then copied the file in there. The font was able to be selected and displayed. However, when I tried to use it to extrude or cut but it will not work.
Laser cutters use .dxf files and so I exported the file and viewed it with https://viewer.autodesk.com/. The areas with both the existing and imported fonts only have a box and no text.
Thank you
