This is a bit ugly. The problem is that the first file in the queue wasn’t queued properly. It was called _Full Printer Carrige_V2 - New Carrige w/Spectra Ink
The slash in the filename is causing some issues.
To start, browse to:
C:\Users\***\AppData\Local\Autodesk\Autodesk Fusion 360\BSLKLQ6ZZ8C3\W.Login\Q
Make a copy of everything in this folder and store it in a folder on your desktop. Don't remove anything! Just make a copy.
The other files seem to depend upon _Full Printer Carrige_V2 - New Carrige w/Spectra Ink, which is causing them to have upload issues as well. Do you happen to know if the "_Full Printer Carrige_V2 - New Carrige w/Spectra Ink" was ever restored from a recovery file? The slash should not be there and I'm not sure how it got there. Any insight you can share on this would be really helpful.
Does _Epson Printhead cleaner slider file depends on _Full Printer Carrige_V2 - New Carrige w/Spectra Ink? It seems that these files may be x-referenced. If so the epson file might have stored a link inside it to the carriage file which makes things a bit tricky.
If not we remove_Full Printer Carrige_V2 - New Carrige w/Spectra Ink from the upload queue manually and it should get things going again.
To do this:
1. Close Fusion 360
2. Open Windows Explorer and browse to:
In this directory, you'll find a file named UploadQueuedFileList.xml
3. Edit this file with a text or XML editor and then delete the first line:
<ID_7385660d-3c29-4025-8c33-c6315782d66d DocId="" OriginalFile="***/Local/Autodesk/Autodesk Fusion 360/***/W.login/F/_Full Printer Carrige_V2 - New Carrige w/Spectra Ink.ebaf337e-8a1e-40de-951b-9112e403969b.f3d" QueueID="3" QueuedTime="20170526T091643.065917">***/Local/Autodesk/Autodesk Fusion 360/***/W.login/Q/7385660d-3c29-4025-8c33-c6315782d66d.f3d</ID_7385660d-3c29-4025-8c33-c6315782d66d>
4. Save the changes
5. Restart Fusion 360
Plan B goes like this:
1. Use the File > New Design from File command to open the file that ends with the below text stored in the folder we made on your desktop. Note if there is a slash in the filename, rename it before opening the file.
2. Use the Save to change the name of the file (make sure there is no slash)
3. Try using the File > Export > Export local archive command to generate a new f3D file (no slashes in the name)
4. Open the Data Panel and Right click on the design named Full Printer Carrige_V2 - New Carrige w_Spectra Ink
5. Select Upload New Version
6. Select the f3D from step 3.
7. Save the design -
This should overwrite the existing design file in the upload and get things moving again.
I hope that helps. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
