Import SLDPRT to my design
Hello, Im using the "personal" F360 setup.
It seems I can "upload" a SLDPRT component or even a assembly SLDASM.
Buy once it appears in my Data Panel, there is no way to "drag" it to my work environment.
This is how it appears in my Data panel. But this yellow symbol is different than all other parts in the panel.
Seems to be linked to the SLDPRT.
Or will it only work if you use a commercial version of Fusion360?
Thank you
HughesTooling
Only standard translatores (STP, Iges, SAT etc.) are included with the personal license. Think you can translate using GrabCAD if you're stuck.
Mark
Mark Hughes
Owner, Hughes Tooling
Thank you. This has solved the issue.
Appreciate the feedback
