Imperial to metric calculator on fusion screen as a popup
does fusion 360 have an add on or  an app that can be  open on the computer at will
TheCADWhisperer
Why not just type in units?
Fusion will take care of the conversion for you.
davebYYPCU
Yes, it is built into the value / parameter input boxes.
Might help....
Thanks for the reply. I do know that i can just type it in, I am just an old 76 year old just starting to learn Fusion 360 and if was  out in the field on a project I probably  would still have a calculator in my hand to check out the math while doing the design. But...........I'll get there!!  New to using forums also.  Thanks again.
jhackney1972
I thought a quick Screencast would help you understand what both @davebYYPCU and @TheCADWhisperer  were trying to tell you.  There is no need for a calculator.
John Hackney, Retired
