Announcements
Image cannot be calibrated
Frank.mauler1959
Message 1 of 13
Frank.mauler1959
Dear Experts,
I try to calibrate a jpg, however, jpg seems to be "inactive" (see screenshot) and I cannot calibrate. Image was converted from HEIC to jpg and just loaded into Fusion. Same result when using png or any other image.
My system is a iMac newest OS with Bitdefender. Any quick idea from your end?
Many thanks and best regards
Frank
Replies (12)
Message 2 of 13
TheCADWhisperer
Message 3 of 13
wmhazzard
How are you trying to calibrate? Did you right click on the image name in the Browser and select calibrate?
Message 4 of 13
g-andresen
Were you able to do this procedure?
günther
Message 5 of 13
Frank.mauler1959
Thanks, as requested attached the *.f3d file.
Best regards
Frank
Message 6 of 13
Frank.mauler1959
Thanks for quick reply. Yes, I did, however, browser icon indicates that image cannot be manipulated
Best regards
Frank
Message 7 of 13
TheCADWhisperer
Do you see the Attachment here? Yes? No?
You must use the forum web browser to Attach file, not email reply.
Message 8 of 13
Frank.mauler1959
As requested the *f3d file.
Message 9 of 13
TheCADWhisperer
Are you on Windows OS or are you on Mac OS?
Can you post screen capture of what you see if you right click on the Canvases>IMG_3755...
Message 10 of 13
Frank.mauler1959
Interesting what I am seeing above. I am on Mac OS 11.1 and I the menue is not opening. Is it a Mac OS challenge?
Message 11 of 13
Frank.mauler1959
That's how it appears on my scree (Mac OS 11.1). Icon indicates that image cannot be
Message 12 of 13
wmhazzard
Right click on the image in the Browser and select (selectable/unselectable), that should let you be able to calibrate it.
Message 13 of 13
Frank.mauler1959
Perfect, that works. Many thanks.
