Announcements
IGS File import
JasonHVQ34
IGS File import
JasonHVQ34
Hello Everyone,
Is there any plans to add support for sketchline IGES support(data output from Geomagic), I had found a work around utilizing Inventor LT, however now that it is gone I would hope fusion allows import IGES as inventor or freecad could. I have a attached a example file if needed.
Thanks in advance
jeff_strater
at the moment, no.  Fusion does not import curve data from any formats except DWG/DXF.  There are no immediate plans to change this that I am aware of.
Jeff Strater
Engineering Director
JasonHVQ34
That's unfortunate, time to look for a new solution. Thanks for the reply.
