Announcements
IGES and Step Translator Failure
brubowman
brubowman
When I try and export a desigh as a STP or IGES file I get this error - Error: STEPTranslator translator failed to export the asset FusionAssetType of document.
I have restarted and tried with several different models and the failure repeats.
Any ideas?
Replies (7)
TrippyLighting
How are you exporting it ? Directly from within Fusion 360 ?
johnsonshiue
Hi! Does a box also fail to export? If yes, it is probably install related. Please uninstall Fusion and reinstall it.
Many thanks!
Software Test Engineer
TheCADWhisperer
Attach example *.f3d file here that exhibits this behavior.  (Simple cube if your actual data is proprietary.)
Are you using free personal license or are you using paid commercial license.
Can you post >> Screencast Recording << of your export steps?
brubowman
Yes, directly within Fusion 360
brubowman
I am using paid license
brubowman
It also failed to export with a simple box. Will try reinstall now.
Thanks!
brubowman
The reinstall fixed the problem.
Thank you!
